Garmin Forerunner 405 Button Replacement
Introdução
Ir para o passo 1This guide will walk you through the process of replacing a button on the Forerunner 405.
O que você precisa
Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
Lift the motherboard out of the watch.
Ferramenta utilizada neste passo:Tweezers$4.99
Push button in and pinch silver clip with tweezers.
Pull silver clip off the pin it is on.
Pull out button and replace.
2Comentários do guia
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
