Ir para o conteúdo principal
Garmin Forerunner 25 Screen Replacement
Suzanne Drumm
Suzanne Drumm e 2 outros colaboradores
Última atualização em May 28, 2018
15 minutos
Moderado
Fotos de ação
Introdução
Ir para o passo 1
The screen is a vital component to a digital smart watch. With the right tools, replacing the screen can be done efficiently and effectively.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. Garmin Forerunner 25 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Screen Replacement: passo 2, imagem 1 %32
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Screen Replacement, Motherboard: passo 3, imagem 1 %32
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Screen Replacement: passo 4, imagem 1 %32
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Screen Replacement: passo 5, imagem 1 %32
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
  6. Garmin Forerunner 25 Screen Replacement, Screen: passo 6, imagem 1 %32
    • Remove gold piece in the corner using the pointed side of the 4 spudger.
    • Any spudger with a pointed end should work to remove this piece.
  7. Garmin Forerunner 25 Screen Replacement: passo 7, imagem 1 %32
    • Pry the screen up with a plastic opening tool.
    • Any plastic tool with a flat edge should work to remove the screen.
    • Remove the screen.
Conclusão
Suzanne Drumm
Membro desde: 03/21/18
85 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G3, Baechle Spring 2018 Membro de IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 1,792
