Ir para o conteúdo principal
GUESS Steel G95370L Battery Replacement
Jason Tsang
Jason Tsang e 4 outros colaboradores
Última atualização em February 25, 2025
8 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
This is a simple GUESS watch battery replacement guide. Watches lose energy after extended usage, however this does not mean you need to purchase a new watch. Just changing the battery will restore the time and watch you need. It requires no prior expertise and takes about 8 minutes to complete from start to end. This replacement takes only two tools: tweezers and a flat head screwdriver. After following the steps in the guide, to finish the job just repeat the steps in reverse order. Take caution while handling your watch because the tools you're using might easily scratch it. If a new battery is required, here is a link to one.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. GUESS Steel G95370L Battery Replacement, Battery: passo 1, imagem 1 %32 GUESS Steel G95370L Battery Replacement, Battery: passo 1, imagem 2 %32 GUESS Steel G95370L Battery Replacement, Battery: passo 1, imagem 3 %32
    • Unclasp the watch.
  2. GUESS Steel G95370L Battery Replacement: passo 2, imagem 1 %32 GUESS Steel G95370L Battery Replacement: passo 2, imagem 2 %32 GUESS Steel G95370L Battery Replacement: passo 2, imagem 3 %32
    • Push in the link pin to allow the watch strap to completely open.
  3. GUESS Steel G95370L Battery Replacement: passo 3, imagem 1 %32 GUESS Steel G95370L Battery Replacement: passo 3, imagem 2 %32 GUESS Steel G95370L Battery Replacement: passo 3, imagem 3 %32
    • Pry open the tab located under the watch face with a spudger.
  4. GUESS Steel G95370L Battery Replacement: passo 4, imagem 1 %32 GUESS Steel G95370L Battery Replacement: passo 4, imagem 2 %32 GUESS Steel G95370L Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the plastic holding down the battery with tweezers.
  5. GUESS Steel G95370L Battery Replacement: passo 5, imagem 1 %32 GUESS Steel G95370L Battery Replacement: passo 5, imagem 2 %32 GUESS Steel G95370L Battery Replacement: passo 5, imagem 3 %32
    • Take out the battery with tweezers.
  6. GUESS Steel G95370L Battery Replacement: passo 6, imagem 1 %32 GUESS Steel G95370L Battery Replacement: passo 6, imagem 2 %32 GUESS Steel G95370L Battery Replacement: passo 6, imagem 3 %32
    • Replace the battery with the new one.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Tsang
Membro desde: 02/03/23
163 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-1, Andersen Winter 2023 Membro de UC Davis, Team 2-1, Andersen Winter 2023
UCD-ANDERSEN-W23S2G1
4 Membros
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 43
Últimos 30 dias: 210
Ao todo: 3,115
