GD Midea FT30-3D Motor Replacement
Introdução
Ir para o passo 1This installation guide will demonstrate how to remove all of the components around the main fan blade motor.
O que você precisa
Release the 3 clips that attach the front fan guard to the rear fan guard.
Remove the spinner from the center of the fan blade.
So how do i take the spinner off the fan
H how do I take the spinner off the center of a fan I don't know how
Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
the two wires of capacitors are connected where ?? please guide me.
At the base of the upper assembly there is a plug which conceals a screw.
The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
10 outras pessoas executaram este guia.
4Comentários do guia
Hey. Could you tell me where to buy the spare motor from please?
where can i buy the motor?
Where can I buy the motor???
