Ir para o conteúdo principal
Fujifilm FinePix Z5 Optical Lens Replacement
Inga Direktorchuk
Inga Direktorchuk e 5 outros colaboradores
Última atualização em May 6, 2020
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
The optical lens is frequently reported as 'not working' or broken. This guide will take you through the steps of removing the malfunctioning lens and installing a new one.
O que você precisa
Ferramentas
Exibir mais…
  1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: passo 1, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: passo 1, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: passo 1, imagem 3 %32
    • Remove the two screws from the right side of the camera and the two screws from the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Optical Lens Replacement: passo 2, imagem 1 %32
    • Remove the three screws from the bottom of the camera.
    • Use a three-prong screwdriver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Optical Lens Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 3, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 3, imagem 3 %32
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Optical Lens Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 4, imagem 2 %32
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is an orange ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Optical Lens Replacement: passo 5, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool to flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Optical Lens Replacement: passo 6, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 6, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 6, imagem 3 %32
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold foil which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw anchoring the motherboard on the right.
  7. Fujifilm FinePix Z5 Optical Lens Replacement: passo 7, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 7, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 7, imagem 3 %32
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Optical Lens Replacement: passo 8, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 8, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 8, imagem 3 %32
    • Hold wires on the left with an index finger, to keep them out of the way.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
  9. Fujifilm FinePix Z5 Optical Lens Replacement: passo 9, imagem 1 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 9, imagem 2 %32 Fujifilm FinePix Z5 Optical Lens Replacement: passo 9, imagem 3 %32
    • Lift the lens off of the camera base (there is nothing anchoring it down).
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 927
