Ir para o conteúdo principal
Fujifilm FinePix S9500 Case Top Removal
Kory Masco
Kory Masco e 2 outros colaboradores
Última atualização em June 5, 2023
5 - 10 minutos
Moderada
This is a guide for removing the case top of the Fujifilm FinePix S9500 camera. In order to replace parts on this camera, it is necessary to first remove the case top. This guide will provide instructions on how to do so.
O que você precisa
Ferramentas
  1. Fujifilm FinePix S9500 Case Top Removal, Fujifilm FinePix S9500 Case Top Removal: passo 1, imagem 1 %32 Fujifilm FinePix S9500 Case Top Removal, Fujifilm FinePix S9500 Case Top Removal: passo 1, imagem 2 %32 Fujifilm FinePix S9500 Case Top Removal, Fujifilm FinePix S9500 Case Top Removal: passo 1, imagem 3 %32
    • Locate and remove two screws. They are M1.7 x 5.0 in size.
    • The first screw is below and to the left of the command dial on the back of the camera.
    • The second screw is on the right side of the camera, to the right of the strap mount.
  2. Fujifilm FinePix S9500 Case Top Removal: passo 2, imagem 1 %32 Fujifilm FinePix S9500 Case Top Removal: passo 2, imagem 2 %32 Fujifilm FinePix S9500 Case Top Removal: passo 2, imagem 3 %32
    • To access the flash on the camera, locate the button on the left side and press it to open.
    • It's important to have the flash open to avoid any interference during disassembly.
  3. Fujifilm FinePix S9500 Case Top Removal: passo 3, imagem 1 %32 Fujifilm FinePix S9500 Case Top Removal: passo 3, imagem 2 %32 Fujifilm FinePix S9500 Case Top Removal: passo 3, imagem 3 %32
    • To open the case, gently push upward in the area just below the command dial with your thumb.
    • The top should pop up, but not fully detach.
    • To release the catch located on the left of the command dial and at the base of the flash, place your thumb to the right of the command dial and push upwards at a 45° angle towards the flash.
Conclusão
Kory Masco
Membro desde: 03/24/23
103 Reputação
Autoria de 1 guia
Equipe
Casper College, Team 1-1, Lareau Spring 2023 Membro de Casper College, Team 1-1, Lareau Spring 2023
CASC-LAREAU-S23S1G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 257
