Ir para o conteúdo principal
Fujifilm FinePix S4200 Lens Replacement
Joshua Greer
Joshua Greer e 3 outros colaboradores
Última atualização em April 21, 2020
1 - 2 horas
Difícil
Use this guide to replace the lense in the Fujifilm Finepix S4200. This guide requires the use of a Phillips 000 screwdriver and soldering iron. Previous soldering experience is recommended.
O que você precisa
Ferramentas
  1. Fujifilm FinePix S4200 Lens Replacement, Lens: passo 1, imagem 1 %32
    • Turn off the camera by pushing the ON/OFF switch as shown.
  2. Fujifilm FinePix S4200 Lens Replacement: passo 2, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 2, imagem 2 %32 Fujifilm FinePix S4200 Lens Replacement: passo 2, imagem 3 %32
    • Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
  3. Fujifilm FinePix S4200 Lens Replacement: passo 3, imagem 1 %32
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Lens Replacement: passo 4, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 4, imagem 2 %32 Fujifilm FinePix S4200 Lens Replacement: passo 4, imagem 3 %32
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Lens Replacement: passo 5, imagem 1 %32
    • Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
    • Remove the top casing by pulling upwards.
  6. Fujifilm FinePix S4200 Lens Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 6, imagem 2 %32
    • Carefully remove the LCD screen.
    • Gently pull on orange tab until it is free. This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Lens Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 7, imagem 2 %32
    • Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
    • Use the Phillips #000 screwdriver.
  8. Fujifilm FinePix S4200 Lens Replacement: passo 8, imagem 1 %32
    • Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
    • Caution: Orange strips are susceptible to tearing.
  9. Fujifilm FinePix S4200 Lens Replacement: passo 9, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Lens Replacement: passo 10, imagem 1 %32
    • Use a soldering iron to desolder the five connections shown.
    • Caution: After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Lens Replacement: passo 11, imagem 1 %32
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Lens Replacement: passo 12, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 12, imagem 2 %32
    • Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
    • Using a Phillips #000 screwdriver, remove the 10mm screws.
  13. Fujifilm FinePix S4200 Lens Replacement: passo 13, imagem 1 %32
    • Slowly lift up the metal plate and remove it from the camera.
  14. Fujifilm FinePix S4200 Lens Replacement: passo 14, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the 10mm screw.
  15. Fujifilm FinePix S4200 Lens Replacement: passo 15, imagem 1 %32 Fujifilm FinePix S4200 Lens Replacement: passo 15, imagem 2 %32
    • Remove the inner lens.
    • Caution: Be careful while removing the lens.
  16. Fujifilm FinePix S4200 Lens Replacement: passo 16, imagem 1 %32
    • Change the broken inner lens with a new inner lens.
    • Reassemble the camera.
Conclusão
Joshua Greer
Membro desde: 10/31/18
253 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G5, Harley Fall 2018 Membro de IUPUI, Team S1-G5, Harley Fall 2018
IUPUI-HARLEY-F18S1G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 41
Duração total: 2,970
