Ir para o conteúdo principal
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Emmanuel Emedeke
Emmanuel Emedeke e 2 outros colaboradores
Última atualização em 2 de set de 2023
1 - 2 horas
Moderado
Introdução
Ir para o passo 1
Flat-screen TVs are often secured to the wall using wall mounts. If your wall mount (Mounting Dream MD2462) is coming out of the wall, you can use this guide to repair it. Loose screws can potentially cause the TV to fall out of the wall, creating a safety hazard. Be sure to unplug the cables in your TV before beginning this repair.
It is also essential to note that this product contains small items which may be choking hazards for children. Before beginning this guide, make sure that all the parts are in good condition. The product also includes some extra hardware components, which might not be needed.
O que você precisa
Ferramentas
Exibir mais…
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 1, imagem 3 %32
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 2, imagem 3 %32
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 3, imagem 3 %32
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 4, imagem 1 %32
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 2 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 5, imagem 3 %32
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 6, imagem 2 %32
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, imagem 1 %32 Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 7, imagem 2 %32
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: passo 8, imagem 1 %32
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Emmanuel Emedeke
Membro desde: 09/17/20
184 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 55
Ao todo: 5,803
