Ir para o conteúdo principal
Fender Starcaster Pickguard Removal
O que você precisa
  1. Fender Starcaster Pickguard Removal, Loosen the Strings: passo 1, imagem 1 %32 Fender Starcaster Pickguard Removal, Loosen the Strings: passo 1, imagem 2 %32 Fender Starcaster Pickguard Removal, Loosen the Strings: passo 1, imagem 3 %32
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster Pickguard Removal, Remove the Strings from the Tuning Pegs: passo 2, imagem 1 %32 Fender Starcaster Pickguard Removal, Remove the Strings from the Tuning Pegs: passo 2, imagem 2 %32
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: passo 3, imagem 1 %32 Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: passo 3, imagem 2 %32 Fender Starcaster Pickguard Removal, Remove the Strings from the Bridge: passo 3, imagem 3 %32
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
  4. Fender Starcaster Pickguard Removal, Remove the Knobs: passo 4, imagem 1 %32
    • While it is not necessary to remove the potentiometer knobs in order to remove the pickguard, it is much easier to remove them while the pickguard is attached to the guitar.
    • The knobs are removed simply by pulling up on them. Be mindful not to pry too much, as older components may feel stuck at first, and you do not want to break the pickguard, knob, or potentiometer.
  5. Fender Starcaster Pickguard Removal, Remove the Selector Switch Cap: passo 5, imagem 1 %32 Fender Starcaster Pickguard Removal, Remove the Selector Switch Cap: passo 5, imagem 2 %32
    • As with the knobs, the switch cap may be removed prior to removing the pickguard.
    • Grip the cap firmly, and pull up to remove it from the switch. Be aware that the switch may move, and to be careful so that you do not break it.
  6. Fender Starcaster Pickguard Removal: passo 6, imagem 1 %32 Fender Starcaster Pickguard Removal: passo 6, imagem 2 %32
    • Once the cap and knobs have been removed, you may begin removing the screws around the perimeter of the pickguard.
    • Do not remove the screws on the electronics.
  7. Fender Starcaster Pickguard Removal, Remove the Pickguard: passo 7, imagem 1 %32 Fender Starcaster Pickguard Removal, Remove the Pickguard: passo 7, imagem 2 %32 Fender Starcaster Pickguard Removal, Remove the Pickguard: passo 7, imagem 3 %32
    • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
    • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Conclusão
Equipe
Pasco Hernando, Team 5-3, Prince Fall 2014 Membro de Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Membros
Autoria de 10 guias
1Comentário do guia
This process describes only how to access the internals of the guitar — how to MOVE the pick guard. NOT how to actually REMOVE it, as indicated in the title. And removing it is what is required if we were talking about 'removing the pick guard...to change the style,' as noted in the introduction.
stantondvx - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 32
Ao todo: 7,083
