Fender Frontman 15r Speaker Replacement
Introdução
Vá para o passo 1If the speaker is dead or blown, install a new one.
O que você precisa
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
To install the new speaker, follow the instructions given in reverse.
Uma outra pessoa concluiu este guia.
