Ir para o conteúdo principal
Felco Gartenschere - Pruners Disassembly
O que você precisa
  1. Felco Gartenschere - Pruners Disassembly, Various types available: passo 1, imagem 1 %32
    • There are several types - e.g. also for left-handers, here a Felco Nr 4 is shown.
  2. Felco Gartenschere - Pruners Disassembly, Release mother: passo 2, imagem 1 %32
    • First, the upper nut SW 13 is released, then the scissors is turned over.
    • The spring can be easily removed.
  3. Felco Gartenschere - Pruners Disassembly, Release screw from below: passo 3, imagem 1 %32
    • Now the hinge screw can be unscrewed. Here SW 14 is used Next to it lies the spring and the lock nut.
    • Now the scissors can be completely disassembled.
    • The blade is pinned with three bolts in the handle half and usually dissolves easily.
  4. Felco Gartenschere - Pruners Disassembly, The items: passo 4, imagem 1 %32
    • The scissors are disassembled. We see the pivot nut, the hinge screw, the spring, the two handles and the blade.
    • The blade is ground on one side. Sharpen the beveled edge with about 15 degrees, only deburr the straight edge with a maximum of 5 degrees.
    • The parts should be free from rust and freshly oiled or greased.
Conclusão
Repeat the steps in order to reassemble your device.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
VauWeh
Membro desde: 10/19/15
179.194 Reputação
Autoria de 225 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
Membros da 15
Autoria de 931 guias
2 comentários
Does the fixed bolt need Locktight or thread locker applied to its thread to stop it coming loose in operation?
Nicholas Little - Responder
I did not use a thread locker and ist works until today.
VauWeh -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 1,953
