Ir para o conteúdo principal
FAO Schwarz Apex 1 Front Axle Replacement
O que você precisa
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, imagem 1 %32 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, imagem 2 %32 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, imagem 3 %32
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: passo 2, imagem 1 %32
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: passo 3, imagem 1 %32 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: passo 3, imagem 2 %32
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: passo 4, imagem 1 %32
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: passo 5, imagem 1 %32
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, imagem 1 %32 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, imagem 2 %32 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, imagem 3 %32
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: passo 7, imagem 1 %32 FAO Schwarz Apex 1 Front Axle Replacement: passo 7, imagem 2 %32
    • Position the axle entirely upright before lifting away from the vehicle.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 231
