Ir para o conteúdo principal
Epiphone ES-335 PRO Volume Knob Replacement
Michaih Ley Bayani
Michaih Ley Bayani e um outro colaborador
Última atualização em March 16, 2023
5 minutos
Muito fácil
Introdução
Ir para o passo 1
Follow these steps to replace the volume knob on your Epiphone ES-335 PRO electric guitar. You may need to replace this if the volume knob is chipped or broken. If the volume knob that you are using to replace does not fit, then it is not the correct volume knob for the guitar.
  1. Epiphone ES-335 PRO Volume Knob Replacement, Volume Knob: passo 1, imagem 1 %32
    • Locate on the guitar's body the volume knob you wish to replace.
    • Get a firm grasp on either side of the knob. Try to get underneath the knob as much as you can.
  2. Epiphone ES-335 PRO Volume Knob Replacement: passo 2, imagem 1 %32
    • Pull the knob firmly until the knob pops off.
    • Do not use pliers to grasp the knob or it might slip off the knob and damage the guitar's body.
Conclusão
1Comentário do guia
But the question is: is the replacement knob metric? which knob to buy? Thanks!
Will Kimbrough - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 33
Ao todo: 1,432
