Ir para o conteúdo principal
Epiphone ES-335 PRO Pickguard Replacement
Michaih Ley Bayani
Michaih Ley Bayani e um outro colaborador
Última atualização em July 28, 2020
5 - 10 minutos
Fácil
Guia do aluno destaque
Follow these steps to replace the pickguard on your Epiphone ES-335 PRO electric guitar. This may be necessary because the pickguard is chipped or broken due to an accident. You may also want to change the pickguard to change the design of the guitar.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: passo 1, imagem 1 %32
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: passo 2, imagem 1 %32 Epiphone ES-335 PRO Pickguard Replacement: passo 2, imagem 2 %32
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Conclusão
Um comentário
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 20
Últimos 30 dias: 83
Duração total: 5,274
