Ir para o conteúdo principal
Emson Star Wars R2-D2 Humidifier Fan Replacement
Yash Chari
Yash Chari e 4 outros colaboradores
Última atualização em January 15, 2018
6 - 10 minutos
Moderada
Guia do aluno destaque
The fan is located in the base of the humidifier. It is used to evaporate the water present in the reservoir. If the heating filament and the valve are both functioning properly but still no vapour is being produced, then one might have a faulty fan. This guide demonstrates the way to replace a faulty fan.
O que você precisa
Ferramentas
Exibir mais…
  1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: passo 1, imagem 1 %32
    • Remove the top cover of the humidifier by pulling upwards.
  2. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 2, imagem 1 %32
    • Grip the dial from the front of the device and gently pull it away to remove it.
  3. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 3, imagem 1 %32
    • Remove the blue water tank of the humidifier by pulling upwards.
  4. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 4, imagem 1 %32 Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 4, imagem 2 %32
    • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
  5. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 5, imagem 1 %32
    • Remove the blue plastic top by pulling upwards on the middle notch.
  6. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 6, imagem 1 %32
    • This is where the fan is located. Carefully remove the fan from its compartment.
    • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
    • Remove the screws on the printed circuit board using the same PH1 driver.
  7. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 7, imagem 1 %32 Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 7, imagem 2 %32
    • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
Conclusão
4 outras pessoas executaram este guia.
Yash Chari
Membro desde: 02/15/17
240 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-5, Eyestone Spring 2017 Membro de USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 813
