Ir para o conteúdo principal
Electrical Plug Replacement
Tim Spellings
Tim Spellings e 10 outros colaboradores
Última atualização em 15 de jan de 2024
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
A common issue with electronic devices is a severed or damaged wire. Whether a dog chews through a wire, a child playing with scissors cuts a wire, or a large appliance slices through a wire, many have encountered this problem. This guide teaches how to remove a damaged plug and replace it with a new plug. The wiring in the lamp plug must be done correctly in order for the lamp to turn on after the repair is finished. This guide shows how to properly locate the "hot" and "neutral" connections.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Electrical Plug Replacement, Two-Pole Plug: passo 1, imagem 1 %32 Electrical Plug Replacement, Two-Pole Plug: passo 1, imagem 2 %32
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: passo 2, imagem 1 %32 Electrical Plug Replacement: passo 2, imagem 2 %32
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: passo 3, imagem 1 %32 Electrical Plug Replacement: passo 3, imagem 2 %32 Electrical Plug Replacement: passo 3, imagem 3 %32
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: passo 4, imagem 1 %32 Electrical Plug Replacement: passo 4, imagem 2 %32
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: passo 5, imagem 1 %32 Electrical Plug Replacement: passo 5, imagem 2 %32 Electrical Plug Replacement: passo 5, imagem 3 %32
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: passo 6, imagem 1 %32 Electrical Plug Replacement: passo 6, imagem 2 %32
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
    Where can I purchase a new plug
    Marlene4950 - Responder
    You can purchase it at almost every hardware store.
    Toon Konings - Responder
Conclusão
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
18 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Tim Spellings
Membro desde: 07/17/15
571 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 3-2, Rauch SU 2015 Membro de Texas Tech, Team 3-2, Rauch SU 2015
TTU-RAUCH-SU15S3G2
3 Membros
Autoria de 4 guias
7Comentários do guia
Passt - gute Anleitung
Martin Winter - Responder
A version for 3 prong (North American) would be great
James Harrison - Responder
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - Responder
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - Responder
Buy a plug that can be opened with a screw
Toon Konings -
How can you tell hot wire from neutral wire?
Dr. Karakas - Responder
the neutral wire usually has raised ribbing on its sleeve, and the hot wire has a smooth rubber sleeve. (See Step 2 of the guide)
Ben Eccles -
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 85
Últimos 30 dias: 353
Ao todo: 50,616
