Ir para o conteúdo principal
Dyson Pure Cool AM11 Filter Replacement
Zepei
Zepei e um outro colaborador
Última atualização em December 29, 2023
10 - 15 minutos
Fácil
This guide will help you replace the filter in your Dyson Pure Cool AM11 air purifier. A clean filter ensures your purifier works efficiently, providing clean air for your home.
  1. Dyson Pure Cool AM11 Filter Replacement, Filter: passo 1, imagem 1 %32 Dyson Pure Cool AM11 Filter Replacement, Filter: passo 1, imagem 2 %32
    • Ensure the Dyson Pure Cool AM11 is turned off and unplugged from the power source.
    • Stand in front of the device. Firmly grasp the base and the top section. Twist the top section counterclockwise (to your left) to unlock it.
    • Gently lift it away from the base to expose the filter.
  2. Dyson Pure Cool AM11 Filter Replacement: passo 2, imagem 1 %32 Dyson Pure Cool AM11 Filter Replacement: passo 2, imagem 2 %32 Dyson Pure Cool AM11 Filter Replacement: passo 2, imagem 3 %32
    • Grasp the filter housing and pull it upwards to remove it from the device.
    • Take the filter out from the housing.
    • Dispose of it according to your local waste disposal regulations.
  3. Dyson Pure Cool AM11 Filter Replacement: passo 3, imagem 1 %32 Dyson Pure Cool AM11 Filter Replacement: passo 3, imagem 2 %32 Dyson Pure Cool AM11 Filter Replacement: passo 3, imagem 3 %32
    • Unbox your new Dyson filter. Remove any packaging or plastic wrapping.
    • Align the new filter with the housing and then put it back to the base of the device.
    • The filter should fit snugly inside the base. Ensure it is seated correctly and evenly all around.
    • Place the top section back onto the base. Align the two parts and twist the top section clockwise (to your right) until it locks into place.
    • Plug the device back in and turn it on to ensure it’s working properly with the new filter.
Conclusão
Your Dyson Pure Cool AM11 should now be operating with a new, clean filter. Regular filter replacement is key to maintaining the efficiency and longevity of your air purifier.
Zepei
Membro desde: 11/01/23
255 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 41
Duração total: 606
