Ir para o conteúdo principal
Dyson Pure Cool AM11 Base Replacement
Gregory Crimmins
Gregory Crimmins e 4 outros colaboradores
Última atualização em April 29, 2024
5 minutos
Moderada
This Guide is to help you if you need to get access to the inside of your fan to fix wire the motor or other parts. We will walk you through the steps to safely open it up and put it back together.
O que você precisa
Ferramentas
  1. Dyson Pure Cool AM11 Base Replacement, Base: passo 1, imagem 1 %32 Dyson Pure Cool AM11 Base Replacement, Base: passo 1, imagem 2 %32 Dyson Pure Cool AM11 Base Replacement, Base: passo 1, imagem 3 %32
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Base Replacement: passo 2, imagem 1 %32 Dyson Pure Cool AM11 Base Replacement: passo 2, imagem 2 %32 Dyson Pure Cool AM11 Base Replacement: passo 2, imagem 3 %32
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Base Replacement: passo 3, imagem 1 %32 Dyson Pure Cool AM11 Base Replacement: passo 3, imagem 2 %32
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Base Replacement: passo 4, imagem 1 %32 Dyson Pure Cool AM11 Base Replacement: passo 4, imagem 2 %32 Dyson Pure Cool AM11 Base Replacement: passo 4, imagem 3 %32
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
Linha de Chegada
Gregory Crimmins
Membro desde: 11/01/23
109 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 299
