Ir para o conteúdo principal
Ducky One 3 RGB Switch Replacement Guide
Zachary Au
Zachary Au e um outro colaborador
Última atualização em December 21, 2023
30 minutos - 6 horas
Fácil
Introdução
Ir para o passo 1
This guide will help you replace the switches on your Ducky One 3 RGB keyboard. Before you perform this replacement, make sure you have new switches ready to be swapped in. Any switches that are 3-pin should fit in the keyboard. In terms of the switch/keycap puller, any should work.
This guide also includes a cleaning process, which is completely optional, hence the massive difference in minimum and maximum time required.
If you are like me and have the Ducky One 3 RGB keyboard, you might notice that after a few months of use, this keyboard starts to double-click keys. Basically, if you click the letter e on the keyboard, it will come out as "ee" instead of just "e". A lot of people who own this keyboard experience this issue, so don't be alarmed if it happens to you. The best way to fix this is to replace your switches altogether. This guide will help you do just that!
  1. Ducky One 3 RGB Switch Replacement Guide, Switches: passo 1, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide, Switches: passo 1, imagem 2 %32
    • Unplug the keyboard. This can be done directly from the back of the keyboard.
    • Unplugging the keyboard will ensure safety as well as making it easier to work without the LED lights flashing.
  2. Ducky One 3 RGB Switch Replacement Guide: passo 2, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 2, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 2, imagem 3 %32
    • Use the keycap remover tool to pull off all of the keycaps.
    • Push the keycap remover over the keycap until it goes underneath on both sides (see picture 2) and pull it up.
    • The keycaps may pop out so be sure to not lose any!
    • Optional: Take a photo of your keyboard before removing the keycaps to use for future reference when putting the keycaps back.
    • If you do not plan to clean the keyboard, skip to Step 4.
  3. Ducky One 3 RGB Switch Replacement Guide: passo 3, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 3, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 3, imagem 3 %32
    • Place all of the keycaps into a large bowl.
    • Add water until keycaps are all fully submerged.
    • Add dish soap.
    • Use your hands and give the keycaps a wash.
    • Rinse the soap off the keycaps with water under the sink and set them aside on a towel to dry.
    • Face the keycaps upwards so that the characters/letters are towards the ground.
    • Wait a few hours until they are fully dry or it can potentially cause damage to your keyboard.
  4. Ducky One 3 RGB Switch Replacement Guide: passo 4, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 4, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 4, imagem 3 %32
    • Use switch puller tool and pull out all the switches.
    • When pulling, clamp down on the buttons on the top and bottom of the switches.
  5. Ducky One 3 RGB Switch Replacement Guide: passo 5, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 5, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 5, imagem 3 %32
    • Use wet wipes and wipe the keyboard until all dirt/dust is gone or until you are satisfied.
    • Do not use wipes that are too wet so liquid gets into the keyboard. Doing so will potentially cause damage.
  6. Ducky One 3 RGB Switch Replacement Guide: passo 6, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 6, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 6, imagem 3 %32
    • Take the new switches and push them into the empty slots.
    • Push the switches in so that the 2 pins are at the bottom. There are holes in the keyboard switch compartments to guide you.
    • Failing to align pins properly may cause pins to bend and damage switches.
  7. Ducky One 3 RGB Switch Replacement Guide: passo 7, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 7, imagem 2 %32 Ducky One 3 RGB Switch Replacement Guide: passo 7, imagem 3 %32
    • Put all keycaps back onto keyboard. This can be done by aligning keycaps and pushing.
    • If you took a picture of your keyboard in step 2, refer to that image to put keycaps back. Otherwise, search up an image online to help.
  8. Ducky One 3 RGB Switch Replacement Guide: passo 8, imagem 1 %32 Ducky One 3 RGB Switch Replacement Guide: passo 8, imagem 2 %32
    • Plug your keyboard back in. Once again, this is done at the back of the keyboard.
  9. Ducky One 3 RGB Switch Replacement Guide: passo 9, imagem 1 %32
    • The keyboard should be fully functioning with your new switches.
Conclusão
Your keyboard is now complete. If you wish to switch back to your old switches, follow the guide again from the beginning.
Zachary Au
Membro desde: 09/05/23
169 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 104
Ao todo: 2,315
