Drum Head Replacement
Introdução
Vá para o passo 1If your drum head is starting to look worn out or is losing the fullness of its sound, it may be time to replace it. Experienced drummers recommend replacing drum heads every six months or so, and always before recording drums in the studio. Luckily, this is a very straightforward process. This guide will provide you with simple but thorough step-by-step instructions on how to replace your drum head. Once your new drum head has been successfully installed, you can utilize the guide's professional advice on proper tuning techniques to optimize and customize the sound of your new drum head.
O que você precisa
