Ir para o conteúdo principal
Disassembling Sony Cyber-shot DSC-W5 Back Cover
Thomas
Thomas e 6 outros colaboradores
Última atualização em December 18, 2020
10 minutos
Fácil
Introdução
Ir para o passo 1
We will be taking off the back cover, or case, of the camera to gain access to the internal components including the speaker, LCD screen, lens, and motherboard.
O que você precisa
Ferramentas
  1. Disassembling Sony Cyber-shot DSC-W5 Back Cover, Back Cover: passo 1, imagem 1 %32
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Disassembling Sony Cyber-shot DSC-W5 Back Cover: passo 2, imagem 1 %32 Disassembling Sony Cyber-shot DSC-W5 Back Cover: passo 2, imagem 2 %32
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Disassembling Sony Cyber-shot DSC-W5 Back Cover: passo 3, imagem 1 %32 Disassembling Sony Cyber-shot DSC-W5 Back Cover: passo 3, imagem 2 %32
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Conclusão
Thomas
Membro desde: 04/14/10
142 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 15-50, Garner Spring 2010 Membro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 5,726
