Ir para o conteúdo principal
Disassembling Canon EOS Rebel XS Top Panel
Daniel Bussone
Daniel Bussone e 5 outros colaboradores
Última atualização em May 7, 2024
Nenhuma estimativa
Difícil
Introdução
Ir para o passo 1
Use this guide to remove the top panel of the camera.
O que você precisa
Ferramentas
Exibir mais…
  1. Disassembling Canon EOS Rebel XS Top Panel, Latch Side Cover: passo 1, imagem 1 %32
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Top Panel: passo 2, imagem 1 %32
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Top Panel, Disassembling Canon EOS Rebel XS Front Cover: passo 3, imagem 1 %32
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Top Panel: passo 4, imagem 1 %32
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Top Panel, Back Cover: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Disassembling Canon EOS Rebel XS Top Panel: passo 6, imagem 1 %32
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Disassembling Canon EOS Rebel XS Top Panel, Top Panel: passo 7, imagem 1 %32
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Disassembling Canon EOS Rebel XS Top Panel: passo 8, imagem 1 %32
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. Disassembling Canon EOS Rebel XS Top Panel: passo 9, imagem 1 %32
    • You can use your fingers to pull the top panel of the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Bussone
Membro desde: 01/28/11
1.260 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 3-41, Regan Winter 2011 Membro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Membros
Autoria de 21 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 28
Ao todo: 4,093
