Ir para o conteúdo principal
Desk Drawer Hanging File Brace Bar Repair
Abbe Robb
Abbe Robb e 5 outros colaboradores
Última atualização em July 31, 2019
50 minutos
Fácil
Introdução
Ir para o passo 1
Upon completion of this procedure you will have repaired and stabilized the brace bar for hanging files. This process is fairly easy and only requires a basic understanding of carpentry.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Desk Drawer Hanging File Brace Bar Repair, Desk Drawer Hanging File Brace Bar Repair: passo 1, imagem 1 %32
    • Remove all content from the drawer. (If possible, remove the drawer from the desk for better accessibility).
    • Using the pencil, mark reference points where the brace bar is located at the top of the drawer.
  2. Desk Drawer Hanging File Brace Bar Repair: passo 2, imagem 1 %32
    • Use the sandpaper and the wood file to sand the area until it is completely smooth to the touch.
    • This process needs to be done on both sides of the drawer where the brace bar was located.
  3. Desk Drawer Hanging File Brace Bar Repair: passo 3, imagem 1 %32 Desk Drawer Hanging File Brace Bar Repair: passo 3, imagem 2 %32
    • Apply the wood putty to the freshly sanded corners. Smooth the wood putty evenly, applying moderate pressure to ensure stable reinforcement.
  4. Desk Drawer Hanging File Brace Bar Repair: passo 4, imagem 1 %32
    • Wait until the putty has almost completely dried (approximately 30 minutes), at which point use the reference points and replace the brace bar, sliding in from the top of the drawer.
  5. Desk Drawer Hanging File Brace Bar Repair: passo 5, imagem 1 %32
    • Reinforce the brace bar once you have properly placed it in the drawer front with wood putty to ensure stability.
  6. Desk Drawer Hanging File Brace Bar Repair: passo 6, imagem 1 %32
    • Replace the hanging files and enjoy your newly secured hanging file drawer.
Conclusão
From this procedure you will have a stronger, reinforced hanging file brace bar.
Uma outra pessoa concluiu este guia.
Abbe Robb
Membro desde: 09/13/15
173 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 1,564
