Ir para o conteúdo principal
Dell Vostro 5560 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond e 2 outros colaboradores
Última atualização em November 4, 2019
10 - 20 minutos
Fácil
Guia colaborativo
In this guide, we will show you how to remove and replace the Hard Drive.
O que você precisa
Ferramentas
  1. Dell Vostro 5560 Hard Drive Replacement, Removing The Optical-Disk Drive: passo 1, imagem 1 %32
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: passo 2, imagem 1 %32 Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Hard Drive Replacement, Removing the Battery: passo 3, imagem 1 %32
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive: passo 4, imagem 1 %32
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  5. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive Connector: passo 5, imagem 1 %32
    • Disconnect the hard-drive connector from hard drive.
  6. Dell Vostro 5560 Hard Drive Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Linha de Chegada
Johnathan Hammond
Membro desde: 02/28/18
45.210 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 43
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 239
