Ir para o conteúdo principal
Dell Latitude E7470 Network Card Replacement
Jack Teegarden
Jack Teegarden e 3 outros colaboradores
Última atualização em January 10, 2025
20 - 30 minutos
Moderada
Use this guide to replace a faulty or broken Wi-Fi/network card in your Dell Latitude E7470.
The network card might not be vital to the function of a laptop, but it is vital part for you to be connection to basically anything you need to do in your life on the computer.
Unfortunately at this time iFixit doesn't have a troubleshooting guide for the Dell LatitudeE7470. I would recommend before completely replacing you look up a troubleshooting guide to make sure that's what's wrong with it.
Be sure to back up your hard drive before replacing it so you don’t lose any data while you’re doing the replacement. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell Latitude E7470 Network Card Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Network Card Replacement, Battery: passo 2, imagem 1 %32
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Network Card Replacement: passo 3, imagem 1 %32 Dell Latitude E7470 Network Card Replacement: passo 3, imagem 2 %32
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Network Card Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Network Card Replacement, Network Card: passo 5, imagem 1 %32 Dell Latitude E7470 Network Card Replacement, Network Card: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
  6. Dell Latitude E7470 Network Card Replacement: passo 6, imagem 1 %32
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  7. Dell Latitude E7470 Network Card Replacement: passo 7, imagem 1 %32
    • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 871
