Ir para o conteúdo principal
Dell Latitude E6530 CPU Replacement
Ella
Ella e um outro colaborador
Última atualização em March 26, 2022
3 - 10 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
This guide will show how to replace the Socket G2 CPU in your Latitude E6530 laptop.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Dell Latitude E6530 CPU Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the laptop.
  2. Dell Latitude E6530 CPU Replacement: passo 2, imagem 1 %32
    • Pull back the 2 battery tabs which are to the left and the right of the battery.
  3. Dell Latitude E6530 CPU Replacement: passo 3, imagem 1 %32
    • Remove the battery from the laptop.
  4. Dell Latitude E6530 CPU Replacement, Bottom Cover: passo 4, imagem 1 %32
    • Remove the 4 Philips #0 screws from the laptop.
  5. Dell Latitude E6530 CPU Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover from the laptop.
  6. Dell Latitude E6530 CPU Replacement, Heatsink: passo 6, imagem 1 %32
    • Remove the fan connector.
  7. Dell Latitude E6530 CPU Replacement: passo 7, imagem 1 %32
    • Remove the 4 Philips #1 screws on the heatsink.
  8. Dell Latitude E6530 CPU Replacement: passo 8, imagem 1 %32
    • Remove the Fan+Heatsink assembly.
  9. Dell Latitude E6530 CPU Replacement: passo 9, imagem 1 %32 Dell Latitude E6530 CPU Replacement: passo 9, imagem 2 %32
    • Use a paper towel or alcohol swab to clean the thermal paste from the heatsink & CPU.
  10. Dell Latitude E6530 CPU Replacement, CPU: passo 10, imagem 1 %32 Dell Latitude E6530 CPU Replacement, CPU: passo 10, imagem 2 %32
    • Use a flathead screwdriver and turn the CPU lock counter-clockwise.
    • Remember to turn the CPU Lock clockwise when you install the new CPU! If you don't do this, the computer won't boot up.
  11. Dell Latitude E6530 CPU Replacement: passo 11, imagem 1 %32
    • Carefully remove the CPU.
    • Be VERY CAREFUL to NOT bend ANY pins on the CPU.
Conclusão
To reassemble your device, follow these instructions in reverse order. Remember to reapply the thermal paste!
Ella
Membro desde: 08/26/19
2.221 Reputação
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 1,177
