Dell Latitude E6510 Heat Sink Replacement
Introdução
Ir para o passo 1This guide will show you the process of removing and replacing the heat sink system in your Latitude E6510.
O que você precisa
Ferramentas
Locate the tabs that lock the battery in place.
Push tabs towards each other while simultaneously pushing the battery away from the device.
