Ir para o conteúdo principal
Dell Latitude E6420 Backplate Replacement
Madysen Eames
Madysen Eames e um outro colaborador
Última atualização em May 23, 2018
10 minutos
Fácil
Introdução
Ir para o passo 1
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
O que você precisa
Ferramentas
Exibir mais…
  1. Dell Latitude E6420 Backplate Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude E6420 Backplate Replacement, Battery: passo 1, imagem 2 %32
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Backplate Replacement: passo 2, imagem 1 %32
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: passo 3, imagem 1 %32 Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: passo 3, imagem 2 %32
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Backplate Replacement: passo 4, imagem 1 %32 Dell Latitude E6420 Backplate Replacement: passo 4, imagem 2 %32
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Backplate Replacement, Backplate: passo 5, imagem 1 %32 Dell Latitude E6420 Backplate Replacement, Backplate: passo 5, imagem 2 %32
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Backplate Replacement: passo 6, imagem 1 %32 Dell Latitude E6420 Backplate Replacement: passo 6, imagem 2 %32
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
Conclusão
4 outras pessoas executaram este guia.
Madysen Eames
Membro desde: 02/27/18
1.555 Reputação
Autoria de 7 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 36
Ao todo: 2,053
