Ir para o conteúdo principal
Dell Latitude E6400 Battery Replacement
Kyle Frisco
Kyle Frisco e 3 outros colaboradores
Última atualização em June 27, 2016
5 minutos
Fácil
Imagens inconsistentes
Precisa de mais images
I am going to teach you how to remove the old and defective battery, then how to install the new battery . This will be a very easy and simple process requiring very little tools.
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Battery Replacement: passo 2, imagem 1 %32
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 Battery Replacement: passo 3, imagem 1 %32
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
Conclusão
5 outras pessoas executaram este guia.
Kyle Frisco
Membro desde: 11/16/15
213 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-4, Shastany Fall 2015 Membro de UMass Dartmouth, Team 3-4, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G4
Membros da 4
1 Guia de autoria
3 comentários
Thanks so easy...just bought a refurbished dell how long should I charge the new battery??!
rogerarchambault24 - Responder
amar battery ic nosto sara jabe ki?
Nafisha Lubna - Responder
thx for the help
Aditya C - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 3,827
