Dell Latitude E6330 Screen Replacement
Introdução
Vá para o passo 1If your Dell Latitude E6330 has physical cracks or shattered glass that impacts visibility, or unusual colors, lines on the display or sometimes the screen remains dark even though the laptop is powered on. Use this guide to replace your screen and fix these problems.
The screen is an essential component of your laptop. Damage to the screen can significantly impair the usability of your device. By following this guide, you will be able to replace the screen and restore your laptop's functionality.
Before starting this guide make sure that your Dell Latitude is completely powered off.
O que você precisa
Ferramentas
Open the laptop and unscrew the 2.5 X 3mm screw in the bottom center of screen
