Dell Latitude E6320 SD Card Replacement
Introdução
Vá para o passo 1This nice and easy guide will tell you how you can replace, add and remove an SD/memory card on your Dell Latitude E6320 laptop. It's probably the easiest replacement ever!
O que você precisa
The slot is located in the middle towards the bottom under the trim (at the front nearest you if you were looking at the screen).
If you have an SD card already inserted, press on it to unlatch it from it's place.
Slide the SD card out.
To insert an SD card into the slot:
Slide the card facing upwards (contacts facing down, label facing up) into it's slot
Press on it to latch it into place.
