Ir para o conteúdo principal
Dell Latitude E5500 RAM Replacement
O que você precisa
  1. Dell Latitude E5500 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: passo 2, imagem 1 %32 Dell Latitude E5500 RAM Replacement: passo 2, imagem 2 %32
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: passo 3, imagem 1 %32
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: passo 4, imagem 1 %32 Dell Latitude E5500 RAM Replacement: passo 4, imagem 2 %32
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: passo 5, imagem 1 %32 Dell Latitude E5500 RAM Replacement: passo 5, imagem 2 %32 Dell Latitude E5500 RAM Replacement: passo 5, imagem 3 %32
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Conclusão
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Evan Eldridge
Membro desde: 10/20/16
215 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 2,093
