Ir para o conteúdo principal
Dell Latitude E4300 Keyboard Replacement
Maritza Martinez
Maritza Martinez e um outro colaborador
Última atualização em January 3, 2019
2 - 5 minutos
Muito fácil
The keyboard is a crucial component to your laptop and because it is fragile there is a higher risk of breaking. Use this replacement guide to replace your keyboard. Make sure that you are careful when working with the keyboard because of its fragility. The keyboard must also be removed if you are attempting to replace any components within the laptop, for example, the hard drive or motherboard.
O que você precisa
Ferramentas
  1. Dell Latitude E4300 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Keyboard Replacement: passo 2, imagem 1 %32
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 763
