Introdução
This is very simple compared to RAM removal on this laptop.
O que você precisa
First, as always, power down the laptop and remove the battery., This can be done by pulling the two tabs above the battery and then simply pulling out the battery.
Now, remove the two drive screws, located in the bottom right of the laptop. These are helpfully labeled with a cylindrical hard drive icon.
Now, remove the drive from its cage by removing the single screw holding it in. See the picture for help
To reassemble your device, attach your drive to the bay and follow these instructions in reverse order.
5 outras pessoas concluíram este guia.
