Ir para o conteúdo principal
Dell Inspiron 3542 Hard Drive Replacement
Rachel lindsey
Rachel lindsey e 9 outros colaboradores
Última atualização em November 16, 2022
5 - 15 minutos
Fácil
Ferramentas incorretas
This guide provides steps on how to remove and replace the hard drive for the Dell Inpiron 3542. This will allow you to carefully remove and replace your hard drive if broken, or if you want to upgrade the hard drive.
The hard drive is the device in your computer that stores and retrieves the data that you have saved. If you are running low on space, upgrading your hard drive would allow you to have more space and continue to work. If your hard drive fails, replacing your hard drive will allow you to continue using your computer.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell Inspiron 3542 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Dell Inspiron 3542 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip computer over to the bottom and slide the latches on both sides of battery outwards.
    • Remove the battery from computer.
  2. Dell Inspiron 3542 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 3542 Hard Drive Replacement: passo 2, imagem 2 %32
    • Using a T5 Torx screwdriver, remove a M2.5 x 5mm screw.
    • Slide up on the access door to remove it.
  3. Dell Inspiron 3542 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 3542 Hard Drive Replacement: passo 3, imagem 2 %32 Dell Inspiron 3542 Hard Drive Replacement: passo 3, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the 1 x M2 x 3mm screw.
    • The hard drive can now be slid out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Rachel lindsey
Membro desde: 03/21/17
733 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team S46-G1, Bennett Spring 2017 Membro de Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 34
Duração total: 3,486
