Ir para o conteúdo principal
Dell Inspiron 3520 Optical Drive Replacement
Ian
Ian e um outro colaborador
Última atualização em June 11, 2015
15 minutos
Fácil
This repair process includes the removal of small pieces from the computer, therefore you should have a place to store all the small removable screws. This will make the repair process quicker and easier.
O que você precisa
Peças
Ferramentas
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 3 %32
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, imagem 2 %32
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: passo 4, imagem 1 %32
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 5, imagem 2 %32
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, imagem 2 %32
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: passo 7, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 7, imagem 2 %32
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
Conclusão
5 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.557 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
Membros da 3
Autoria de 5 guias
Um comentário
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 2,688
