Dell Inspiron 15R 5520 Memory Module Replacement
Introdução
Ir para o passo 1In this guide, we will be showing you how to remove and replace the Memory Module.
O que você precisa
Ferramentas
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
2Comentários do guia
I took apart my dell inspiron 15r 5520 to replace the Wi-Fi card & now the touchpad & buttons will not work. What might have I done wrong?
الكمبيوتر يصدر صفاره عدد اربعه ولا يقلع
النظام
