Ir para o conteúdo principal
Dell Inspiron 15-5567 Back Cover Replacement
O que você precisa
  1. Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Back Cover Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5567 Back Cover Replacement: passo 2, imagem 2 %32
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Back Cover Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5567 Back Cover Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-5567 Back Cover Replacement: passo 3, imagem 3 %32
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
Conclusão
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 48
Ao todo: 2,747
