Ir para o conteúdo principal
Dell Inspiron 15 Ram (Memory Module) Replacement
Edward Pacheco
Edward Pacheco e 3 outros colaboradores
Última atualização em May 17, 2016
15 minutos
Fácil
Introdução
Ir para o passo 1
You will be able to remove and replace the Ram in your computer with ease after this guide.
O que você precisa
Ferramentas
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: passo 2, imagem 1 %32
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, imagem 1 %32 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, imagem 2 %32 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): passo 3, imagem 3 %32
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, imagem 2 %32 Dell Inspiron 15 Ram (Memory Module) Replacement: passo 4, imagem 3 %32
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
Conclusão
4 outras pessoas executaram este guia.
Edward Pacheco
Membro desde: 03/06/16
845 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 6,770
