Dell Inspiron 15 3567 Memory Module Replacement
Introdução
Ir para o passo 1In this guide, we will be show how to remove and replace the Memory Module.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot
Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
Press the memory module down until it clicks into place.
4 outras pessoas executaram este guia.
