Ir para o conteúdo principal
DeWalt DWE4011 Power Switch Replacement
Kory Dalesky
Kory Dalesky e 2 outros colaboradores
Última atualização em June 17, 2019
10 minutos
Moderada
The power switch is for turning the device on and off. It can have trouble and not work if the button in the switch box wears out. This is a guide on how to repair the power switch
O que você precisa
Ferramentas
  1. DeWalt DWE4011 Power Switch Replacement, Power Switch: passo 1, imagem 1 %32
    • Turn to the bottom of the device and remove the 1 1/4" screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Power Switch Replacement: passo 2, imagem 1 %32
    • Remove the outer casing by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Power Switch Replacement: passo 3, imagem 1 %32
    • Unscrew the pin that is holding the main power cord in place and remove the cord.
  4. DeWalt DWE4011 Power Switch Replacement: passo 4, imagem 1 %32 DeWalt DWE4011 Power Switch Replacement: passo 4, imagem 2 %32
    • Pull back the tab holding the switch box in place using a nylon spudger. There is one on top and bottom shown in the image.
  5. DeWalt DWE4011 Power Switch Replacement: passo 5, imagem 1 %32
    • Remove the switch box entirely from its normal position. Gently pull off the connections from the switch box to the motor.
  6. DeWalt DWE4011 Power Switch Replacement: passo 6, imagem 1 %32 DeWalt DWE4011 Power Switch Replacement: passo 6, imagem 2 %32
    • Using a small Phillips head screwdriver, remove the screws that hold the white colored wires from the power cord in place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 29
Duração total: 1,496
