Ir para o conteúdo principal
DeWalt DWE4011 Brush Spring Replacement
Jesus Quinones
Jesus Quinones e 2 outros colaboradores
Última atualização em June 17, 2019
15 - 20 minutos
Moderada
The brush spring pushes the brush against the armature. The spring can lose its tensioning properties due to overheat. Make sure to always unplug your device before fixing it. Pay close attention to the position of the spring and only work on one at the time (in case you forget how is position you can look at the other one).
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. DeWalt DWE4011 Brush Spring Replacement, Brush Spring: passo 1, imagem 1 %32
    • Turn to the bottom of the device and remove the 5/8" (17mm) screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Brush Spring Replacement: passo 2, imagem 1 %32
    • Remove outer casing by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Brush Spring Replacement: passo 3, imagem 1 %32
    • Locate the brush springs on either side of the device.
  4. DeWalt DWE4011 Brush Spring Replacement: passo 4, imagem 1 %32
    • Using an iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Brush Spring Replacement: passo 5, imagem 1 %32
    • Remove the spring by sliding it out of the center post (use an iFixit opening tool if needed).
    • When replacing the spring you need to tension it. Watch this video at 1:55 to see how.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 1,325
