DeWalt D28110 Brush Arm Replacement
Introdução
Vá para o passo 1This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
O que você precisa
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Uma outra pessoa concluiu este guia.
