Ir para o conteúdo principal
DJI Spark Internal GPS Replacement
Amelia Hagberg
Amelia Hagberg e 2 outros colaboradores
Última atualização em December 31, 2019
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
If your DJI Spark (model CP.PT.000903) is moving erratically and you believe that the internal GPS is broken, use this guide to gain access to the GPS and replace it. The internal GPS informs the drone of its location and allows it to move by interpreting input from the controller as directions. If the internal GPS of your DJI Spark is faulty or broken, the drone may jump around or fail to respond to input from either the manual controller or virtual controller.
O que você precisa
Ferramentas
Exibir mais…
  1. DJI Spark Internal GPS Replacement, Propellers: passo 1, imagem 1 %32
    • Push down on the propeller that is being replaced.
    Just a warning, I just tried this guide and it is missing tons of steps, so be careful when you try yourself.
    MisterGuy’s Channel - Responder
  2. DJI Spark Internal GPS Replacement: passo 2, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 2, imagem 2 %32
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 1 %32 DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 2 %32 DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 3 %32
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 1 %32 DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 2 %32 DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 3 %32
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
    The middle two screws appear to have their hex holes plugged with clear plastic.
    Basil Yokarinis - Responder
    How do you remove it?
    MontesDesigns -
  5. DJI Spark Internal GPS Replacement: passo 5, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 5, imagem 2 %32 DJI Spark Internal GPS Replacement: passo 5, imagem 3 %32
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Internal GPS Replacement, GPS: passo 6, imagem 1 %32 DJI Spark Internal GPS Replacement, GPS: passo 6, imagem 2 %32
    • Identify the GPS module on the motherboard.
    • The GPS module will be labeled as ‘DJI G116’.
  7. DJI Spark Internal GPS Replacement: passo 7, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 7, imagem 2 %32
    • Remove the four 6.0 mm Phillips #000 screws holding the GPS module to the motherboard.
    GPS module ribbon cable ineed it please tell me some body where should i find
    manzoorsp67 - Responder
  8. DJI Spark Internal GPS Replacement: passo 8, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 8, imagem 2 %32
    • Pick up the GPS module.
    • Carefully disconnect the GPS module ribbon cable from the motherboard.
    • Remove the GPS module.
Conclusão
Amelia Hagberg
Membro desde: 10/21/19
445 Reputação
Autoria de 3 guias
Equipe
5Comentários do guia
How About Spark's Wifi can't find?
Mark Ryan Fontelar - Responder
GPS module ribbon cable is broken where can i buy?
please if some one have it send it to me
i will pay u
manzoorsp67 -
hey, i have a site where you can buy it from.
Abubakar Atif -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 2,195
