DJI Phantom 4 Advanced Propeller Replacement
Introdução
Ir para o passo 1The reason your drone is not flying could be broken or damaged propellers. This guide will fix that problem without any tools needed.
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
