DJI Phantom 3 Standard Remote Controller Battery Replacement
Introdução
Ir para o passo 1This guide will be used to open the DJI Phantom 3 Standard Remote Controller to access and change the battery. If your controller isn't charging properly, check out this troubleshooting page before continuing onto the repair guide. Step 3 should be handled carefully to avoid damage to the connection between the battery and the connection port.
O que você precisa
Position the controller so the back is facing up and the joysticks are resting on the table.
Remove the four 11 mm screws that secure the back plate using a Phillips #0 screwdriver.
Remove the back plate, being mindful of the wires still connected to the device.
