Ir para o conteúdo principal
Cricut Maker Front Door Replacement
Devyn White
Devyn White e um outro colaborador
Última atualização em August 23, 2024
45 minutos - 1 hora
Difícil
Precisa de melhores imagens
Precisa de mais images
Follow this guide if you need to replace the front door of your Cricut Maker or if you need to access other parts of the device that require the door to be removed. The front door of the Cricut Maker holds the closing magnets, which close the machine entirely, keeping debris out, and your machine spic and span.
The door cannot be removed without removing the lid first. That said, if your lid is not magnetizing to the door, or your door is broken and you would like to replace it yourself, this guide is for you.
To be safe, be sure to turn off the device and unplug it from the outlet prior to beginning this repair.
O que você precisa
Ferramentas
Exibir mais…
  1. Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: passo 1, imagem 1 %32 Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: passo 1, imagem 2 %32 Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: passo 1, imagem 3 %32
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Front Door Replacement: passo 2, imagem 1 %32 Cricut Maker Front Door Replacement: passo 2, imagem 2 %32
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Front Door Replacement: passo 3, imagem 1 %32 Cricut Maker Front Door Replacement: passo 3, imagem 2 %32 Cricut Maker Front Door Replacement: passo 3, imagem 3 %32
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Front Door Replacement: passo 4, imagem 1 %32
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Front Door Replacement, Front Door Replacement: passo 5, imagem 1 %32 Cricut Maker Front Door Replacement, Front Door Replacement: passo 5, imagem 2 %32
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Front Door Replacement: passo 6, imagem 1 %32 Cricut Maker Front Door Replacement: passo 6, imagem 2 %32 Cricut Maker Front Door Replacement: passo 6, imagem 3 %32
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Front Door Replacement: passo 7, imagem 1 %32 Cricut Maker Front Door Replacement: passo 7, imagem 2 %32 Cricut Maker Front Door Replacement: passo 7, imagem 3 %32
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Front Door Replacement: passo 8, imagem 1 %32 Cricut Maker Front Door Replacement: passo 8, imagem 2 %32 Cricut Maker Front Door Replacement: passo 8, imagem 3 %32
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Front Door Replacement: passo 9, imagem 1 %32 Cricut Maker Front Door Replacement: passo 9, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Front Door Replacement: passo 10, imagem 1 %32 Cricut Maker Front Door Replacement: passo 10, imagem 2 %32 Cricut Maker Front Door Replacement: passo 10, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Front Door Replacement: passo 11, imagem 1 %32 Cricut Maker Front Door Replacement: passo 11, imagem 2 %32
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Front Door Replacement: passo 12, imagem 1 %32 Cricut Maker Front Door Replacement: passo 12, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Front Door Replacement: passo 13, imagem 1 %32 Cricut Maker Front Door Replacement: passo 13, imagem 2 %32 Cricut Maker Front Door Replacement: passo 13, imagem 3 %32
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Front Door Replacement: passo 14, imagem 1 %32 Cricut Maker Front Door Replacement: passo 14, imagem 2 %32 Cricut Maker Front Door Replacement: passo 14, imagem 3 %32
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
Conclusão
Uma outra pessoa concluiu este guia.
Devyn White
Membro desde: 09/20/22
1.113 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 2,218
