Create a Micro-SIM to SIM Adapter
Introdução
Ir para o passo 1This simple guide will show you how to make a Micro-SIM to SIM adapter out of the old SIM card in the iPhone 2G to the iPhone 3GS, so you can use your new iPhone 4 Micro-SIM in older devices. This process destroys the old SIM-Card. Luckily when you buy a new iPhone 4 they give you a new SIM and deactivate the old one, making the old one useless.
O que você precisa
Peças
Ferramentas
Exibir mais…
Get everything you'll need:
XACTO Knife and a good cutting surface, such as a self healing mat.
Pencil
SIM-Card removal tool or bent paperclip
iPhone 4
An old GSM SIM card that you can sacrifice to make an adapter.
Use an XACTO Knife to cut on the line you traced.
It can be difficult to control the knife when applying enough force to cut through the plastic, so I recommend going lightly for the first couple of times to make a groove. Once you have a properly-shaped groove, go back and apply more force to cut through the plastic. You can also drill 5 pilot holes using a fine drill bit at the vertices. This also helps to guide the knife.
When you are nearly done, flip the SIM-Card over. You should be able to see the outline of the cutout you made on the top side. For a cleaner result, finish cutting the slot from the bottom side.
Remove the piece you cut out of the SIM.
Insert your Micro-SIM Card into the hole you cut out of the SIM.
If the Micro-SIM doesn't fit, you may need to cut away more plastic with the knife to enlarge the hole.
If you cut the hole slightly too big, put a piece of tape over the back of the SIM-Card (the side without the gold contacts) to hold the Micro-SIM in place. Trim away any excess tape with the knife.
97 outras pessoas executaram este guia.
16 comentários
Just a heads up, this could vary easily ruin your SIM card. Better off buying a SIM cutter, faster & exact results.
I just did this with the miniSIM card from my iPhone 4 (ATT) to my iPhone 3GS. First time it was not sucessful, so I pulled it out and repositioned the miniSIM card and it worked perfectly! (Note: In regards to the first post, this method does DESTROY the full size SIM card, but if you are taking these steps this card is MOST LIKELY deactivated and thus garbage. In no way *should* this harm the miniSIM card.)
hahahaha...this is the awesomest and most creative post in the concentrated niche ....... how cm this post is not all over the internet than sim adapters ....and thank you by all heart for telling me this simple trick.....now i wont waste time searching and ordering sim adapters
great trick! Thanks, you saved my day!!
I just leave it here http://microsim-solutions.com/
No need to ruin your phone
