Ir para o conteúdo principal
Crayola Crayon Maker White Plastic Arm Replacement
O que você precisa
  1. Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: passo 1, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: passo 1, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: passo 1, imagem 3 %32
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: passo 2, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: passo 2, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: passo 2, imagem 3 %32
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: passo 3, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: passo 3, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: passo 3, imagem 3 %32
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: passo 4, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: passo 4, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: passo 4, imagem 3 %32
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: passo 5, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: passo 5, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: passo 5, imagem 3 %32
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: passo 6, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: passo 6, imagem 2 %32
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
  7. Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: passo 7, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: passo 7, imagem 2 %32 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: passo 7, imagem 3 %32
    • Remove the green base from the crayon maker and set aside.
    • Locate the clear box.
  8. Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: passo 8, imagem 1 %32 Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: passo 8, imagem 2 %32
    • There are four screws (circled in red) that need to be removed with a Phillips #00 Precision screwdriver.
  9. Crayola Crayon Maker White Plastic Arm Replacement, Open Clear Plastic Box: passo 9, imagem 1 %32
    • Remove five screws (1.5 cm in length) using a Phillips #00 Precision screwdriver and open the clear plastic box.
  10. Crayola Crayon Maker White Plastic Arm Replacement, Check placement of white plastic arm.: passo 10, imagem 1 %32
    • The plastic arm should be positioned as shown in the figure. Adjust the arm's position if necessary.
    • If the plastic arm is broken, contact Crayola for a replacement arm.
Conclusão
Uma outra pessoa concluiu este guia.
Melissa
Membro desde: 10/10/14
210 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Ao todo: 797
