Ir para o conteúdo principal
Crayola Crayon Maker Sliding Lock Mechanism Replacement
O que você precisa
  1. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: passo 1, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: passo 1, imagem 2 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: passo 1, imagem 3 %32
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: passo 2, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: passo 2, imagem 2 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: passo 2, imagem 3 %32
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: passo 3, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: passo 3, imagem 2 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: passo 3, imagem 3 %32
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: passo 4, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: passo 4, imagem 2 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: passo 4, imagem 3 %32
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: passo 5, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: passo 5, imagem 2 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: passo 5, imagem 3 %32
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: passo 6, imagem 1 %32 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: passo 6, imagem 2 %32
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
Conclusão
Heidi Clarke
Membro desde: 09/21/14
222 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 723
